P200, MT1000 connection problem
HFR427
North Carolina
I've been forced to swap computers for programming. I've got two cables that i've tried on this desktop (decently fast for it's age with XP home). I get the P200LB program to run and then during the com connection i get an error, and on reattempt i get fatal serial error. Good battery, correct com port, good radios .Any ideas?
Iron Triangle Ohio... otherweise known as Fostoria
P200
When programming these older radios it's always best to use an older machine around a 486 and the RSS has to be run directly through dos. I have heard of a program out there called MOSLOW to enable you to program older radios with a newer computer. But I would say your best bet when working with these old radios is to try and find you an old computer, They are still floating around out there. Good Luck.
