P25 2 TONE PAGING
patt1345
I am setting up our station pagers for P25 2 tone alerting. In D4 I have setup the talk group and then individual lines for each stations 2 tone configuration. If i chose Tone and then none in D4 and then in D5 add the talk group and then the stations tones under subgroup features, will i get the beep at the beginning of every transmission? I have read in order for the tones to activate on that talk group it must be set to tone and default tone on the actual dispatch talkgroup. Thank you!
amys17
East Sparta, Ohio
In tab d4 Set the talkgroup to alert mode none, then alert tone should stay default tone.
Otherwise it will tone every time a mic is keyed up. But if you put none and none it won't alert at all. But otherwise yes you set the rest up correctly from what you explain
