Hi guys,
I'm doing my 1st steps with P25 digital trunking using the TRX-1 and I will be grateful for some help and clarifications:
After scanning the relevant range I built a list of the Control channel frequencies and their Voice channels and set them up in sites.
When I'm running the scanner it does lock from time to time and decode the signal - hance the frequencies should be ok.
However, reception is far from being optimal.
I rad some posts regarding the ADC, DAC and DSP level and it does change things a little.
1. I'm trying to figure out how to verify that I'm in the best settings for each one of them. Is there something like an info/debug log that can tell me what are the levels of reception?
if not - I thought of getting this info from the display:
Top row - from left to right there is the signal bar, T for Trunking and D2 and at the bottom I have the VC when it decodes.
Which will be effected by what value? (I mean i.e. does lowering the ADC will lower the signal bar? the detection of trunking? I', not sure I'm clear here but the idea is to get some feedback of what levels are correct and what should be changed)
2. On the manual (If I recall correct) it says that ADC DAC and DSP goes hand in hand. I'm missing something here since I thought that ADC is responsible for the incoming level to the digital converter. then it goes to the DSP (Still unsure what does DSP level adapt does...) and DAC is responsible of the level of voice "creation". As I understand - I can be OK with ADC - feeding the DSP with the right level and then play all the way with DAC and change how it sounds but it doesn't have to go in conjunction to the input level of the ADC.
Doesn't match what the manual say do what am I missing here ?
3. When running the scanner on the sites list it starts without any detection and when time goes it gets better. as if it fine-tunes it-self or something a like.
I thought that these are missing frequencies but after a couple of sessions in which Ive added missing frequencies I got t the point in which there are no new freq. but it still behaves the same. Any reason for that?
Any tips and ideas will be appreciated
Jim
Jim
