txpss
Ok guys im racking my brain here. Ive got a Motorola Astro Spectra (VHF W5 Hi Power trunk mount) and im working on programming in P25 channels. Ive been using a Kenwood TK-5210 P25 handheld and I can not get the motorola and the kenwood working correctly. The kenwood can transmit and the astro spectra will recieve and you hear audio. When you transmit from the Astro spectra the kenwood shows its picking up something but there is no audio at all.
Has anyone had any problems with kenwood and motorola like this? The only thing I can think of is to set the kenwood to a "receive all/open nac" setting instead of NAC setting i have it set on and see if I can get audio.
The motorola has been checked out by a radio shop and the kenwood has been to the factory to be fixed and retuned after someone broke the antenna connector.
Any ideas?
And just to put it out...
TX 158.61250 NAC 560
RX 158.61250 NAC 560
ASTRO System - 1
Digital Modulator Type - C4FM
Rx Unmute Rule - Normal Squelch
Unmute/Mute Type - And UnMute, Or Mute
RX Voice/Signal Type - ASTRO
Rx Unmute Delay (ms) - 1
Rx Emphasis - Checked
Busy LED - Checked
TX Time Out Timer - 1 (Infinite)
Transmit Deviation - 2.5 kHz
Trasmit Emphasis - Checked
Reverse Burst/Turn-Off Code - Checked
Channel Spacing - 12.5 kHz
Tx Voice/Signal Type - ASTRO
Kenwood TK-5210K3
Squelch Type - NAC
Channel Type - P25
Any ideas?
ASTRO System - 1
Busy LED - Checked
Kenwood TK-5210K3
Squelch Type - NAC
Channel Type - P25
