I posted about this on the GRE forum but didn't quite get the help I was after. So thought I would try here since maybe someone is listening to the same P25 site listed below:
Windsor Public Safety Trunking System, Windsor, Ontario - Scanner Frequencies
I've only had my GRE PSR800 for about a month and a half now but during that time I haven't seen this happen on that P25 system at all. It started happening this Friday, in the evening. I began seeing quite a bit of activity on a TGID I had only seen a few RIDs on. The TGID is 12 which I know isn't listed on RR yet since I don't know what it is. Its right in the middle of the main police dispatch TGID's, and I began to see the same dispatch RID's used on it as well. The city was having its annual Zombie Walk that night so I thought the TGID could be some sort of special events TGID for nights like that.
I set the scanner to record over night and in the morning I looked over the audio file data. I thought my scanner had messed up since for the one TGID 12, it showed the name I had for it, but the TGID for it went from 11 to 12, 13 and 14. Same TGID name, different TGID number.
In the morning though as I began monitoring more and being able to see the display now, I noticed it would stop on one of those TGID's then say 'patch' on the display to the right of TGRP. Then the TGID number would change and flash between 2 different TGIDs like between 11 and 14 for example.
I have all four of these TGIDs listed as using dispatch RIDs for police. I've only seen 'patch' show on the display once before when a ambulance was transporting to a hospital. Its not even talked about in the manual for my scanner.
Anyway... I've been told in the GRE forum that patches take place all the time within PD. This is the first i've seen it here though but I have been away from scanning for about a year. I was wondering if anyone else from Windsor has seen it happen, but I know most probably aren't monitoring TGID 12. I'm still searching out RIDs and TGIDs so that's why I'm following them.
I was also told that its like a dispatcher gets too busy or short, then 'patches' one TGID to another. I don't know why its suddenly happening now though for the past 3 days. Maybe they started something new? I've only seen it happen between those 4 TGIDs. If it is common, maybe someone can explain what is taking place if they know.
I attached a photo here from the audio files section from tonight also, where you can see the one TGID 12 which I call Special Events 1 for now, has its TGID number go from 11, 12, 13 and 14 over the course of a short time. Making it so hard for me to follow and track RIDs. Especially when the audio is encrypted and I can't tell what's going on. I actually notice in the image below that even other ones besides 12 changes too like PD Central will have its TGID change from 13 to 14. Likely another patch taking place.
