P25 Phase 1 Trunking with DSD+ Fast Lane
mrlindstrom
Klein, TX
Should DSD+ be able to trunk follow a P25 system? I have it tuned to the CC and am seeing the data flow, but no channels or calls are ever populated in the Channel Activity window.
bama9999
Gulf Coast
You can use Unitrunker to do the trunking and then feed the output into DSD+ to decode it so you can listen to it. DSD+ will trunk some systems, but currently it won't trunk P25. Also even if you do trunk the P25 system with Unitrunker, DSD+ will only decode phase 1 and not phase 2.
