P25 Phase II TDMA receive only
KRJL10-8
Is there a way to monitor a Phase 2 system without affiliating with the system if LLA is enable on the system?
I have an XG-75 I would like to just use as a scanner if possible. Thanks.
Thunderknight
Bletchley Park
Don't know the answer as I have to yet to see a system with LLA. Can you say which system you want to monitor that is using LLA?
(I do know this would work without LLA).
snoopyII
On the other side of the tracks
I wouldn't think LLA should be an issue? From what documents are available on the web LLA comes into play when the radio tries to affiliate, since your not affiliating, it should be the same as any other system. For lack of a better analogy, LLA is more like what you'd think a system key is.
ElroyJetson
My understanding...and this is what I have HEARD, not what I have experienced...is that LLA only applies to radios that have the LLA option.
In Motorola speak, it's called radio authentication. Only a radio that HAS the radio authentication feature can use radio authentication. A radio that does not have this feature can still listen without being an authorized subscriber radio if it is correctly programmed.
But if it has the LLA feature, then it can't hear the system if it's not authenticated.
Since P25 standards are the same for any vendor, it would seem likely that LLA behaves in the same manner as radio authentication.
A Harris vendor should be able to delete the LLA option from your radio for a small price. Usually people buy features to ADD, but features can be deleted, too.
