I just got an APX 8000 I can call my own, and after a few hours of battling with the APX CPS and Unitrunker, I have a working no-affiliate trunk scanning setup now!
While I was initially setting this up, I ran into the problem of receiving the Control Channel and getting told the talkgroup - so my radio would see the talkgroup of interest - but I'd have no audio. I had origrinally put the voice channels into the Channel ID section of my trunking system page, but realized that didn't make sense, so threw Unitrunker at the system and noticed there was another section about Bandplan, and tried that in the order I saw it in (Lo)... Radio Reference ought to list this section in system pages as well!
So questions about bandplans and configurations:
- Does the order of Control Channels matter? The site I'm listening to of the system I'm interested in had the primary CC as the first one, so no problem there, but other sites have the primary CC listed after alternate CCs.
- The radio gets an idea of where to tune to from the Control Channel(s), right?
- So why is there a need for a "bandplan"? Is this because of rebanding/reconfiguration? This means that instead of going to a default channel that's calculated, the radio uses the Channel ID section as a lookup table? Why not have the site CC tell the radio that information?
Questions about multi-site systems (the system I'm currently listening to is https://www.radioreference.com/apps/db/?sid=7127):
- I currently have "Coverage Type" disabled. AIUI, as far as my radio is concerned, this is a one site trunking system. I'd love to figure out how to set up all the other sites. I tried doing this as "SmartZone & OmniLink" (since that was the only option that gave me the ability to edit the RFSS field in the "Site Alias" section, and I think the band plan/"Channel ID" is the same (per Unitrunker).
- Do I just need 1 trunking personality, or should I be setting up separate personalities for the talkgroups that only reside on one site and use "Preferred Sites"? I tried this, but from what I can tell I've been missing a call or two.
- Do I just clump all the control channels (primary and alternates) for all the sites in the Control Channels section? There's no way to label "these control channels are for this site"... This seems highly inefficient.
Questions about NAT scanning - after creating the trunking system and personality, having to:
- create a conventional personality
- set up 2x the channels in zone/channel assignments
- create a scan list
- tie the scan list back with the personality
for each and every single talk group, this is starting to get tiresome and painful. There can't be a better way, is there?
Honestly, if you work at MSP/BAPERN/etc. or on the "Commonwealth of Massachusetts P25 System"/"Metro Area Simulcast System", I'd love to work/intern for you. Spending these few hours futzing around in the APX CPS and watching the help videos have been completely enlightening.
