Hi all...
I live literally right smack in the middle of two towers broadcasting our P25 communications. Each tower is about 3 miles away but in opposite directions. As you probably already figured, my question is related to simulcast/multicast distortion. I have tried dealing with this using different scanners (Pro-197 and Bearcat BCD996XT), multiple antennas (stubbie, stock telescopic, a dipole, a yagi, a corner reflector, I've even tried a paper-clip antenna and a "Can-tenna"). Directional, non-directional, attenuate, no attenuate, control channel only, etc... I've tried countless settings like Adjust Level, Adjust Mode, etc... I've tried the scanner/antenna in countless spots (indoors) including the basement hoping that reduced the signal some.
Anyways... With all that said. I know that I'm pretty much screwed. HOWEVER, I'd like to toy with the idea of setting up the antenna so that its "blocked" from the signal of one of the towers. I thought the Can-tenna was a great idea to zero in on one signal, but it didn't make much difference.
So, any ideas how I can block off one tower? And btw, yagi didn't help either. So far, my best scanner is the BCD996XT with a stubbie. Online here: Frederick County Airport, Highway, Police, Fire and EMS The Pro-197 is a mess! Its hating life listen to it here: Frederick County Fire
Thanks all...
Thanks all...
