P25 tdma
Radar412
split between Berkeley Springs, WV & Wyoming
There is a discussion on the Scan DC blog in reference to Loudoun County and PG County. They are apparently deploying a TDMA backwards compatible system for testing in anticipation of Phase II of P25. The concern is that apparently the current market digital trunkers cannot translate the audio when the system is operating in that mode. My question to UP Man or anyone else that has relevant info is, Is Uniden looking at incorporating P25 TDMA in any future products?
mdulrich
Van Wert, Ohio
It's been stated many times in the past that there will be no comments about future plans for scanners. Uniden typically allows advance notice about 6 months before a new scanner comes out. So we are AT LEAST 6 months and 1 day from any new scanner that could incorporate TDMA. :lol:
Plus there will need to be systems in place that the manufacturers can test their scanners on before there will be any on the market.
Mike
cpuerror
Ontario, Canada
Normally even minor product improvements are kept secret until they are released to market. For something as major as this there are only going to be a few select people at Uniden who will know. The exception to this is when they know they will not be implementing a feature, such as the case with ProVoice, in which case Upman will usually chime in with a resounding no and an explanation why.
maus92
The OP
Let's put it this way - if Uniden does not develop a P25 / Phase II TDMA scanner, the public safety scanner market will die. TDMA is the future.
KE4ZNR
Radio Geek
Who has said that they won't?
As others have said in this thread we are aways off from anything showing up on the radio market from either GRE or Uniden.
Marshall KE4ZNR
AZScanner
Somewhere in this room. Right now, you're very col
Given how well *cough, cough* today's digital trunkers work on simple FDMA P25 Phase I, the first generation of TDMA scanners will probably be bricks.
The question is, how long will today's current FDMA P25 systems be in use? Phoenix (and surrounding municipalities) have spent a gazillion dollars on the current system, so unless switching to PII involves the flip of a switch (somehow I doubt it, judging from the pa$t when it come$ to the Big Batwing) it's gonna be a long time (hopefully) before Phase II is rammed down our throats.
Personally, I think it's a mistake. Every layer of technological complexity we add to these radios puts our first responders at some degree of risk - it's simply more pieces of a process that can fail. If TDMA is all that fantastic, why not just do away with the radios altogether and use GSM cell phones instead? With PTT and text messaging capability, we could replace both the MCT and the police band radio with a simple, cheap, easily replaced and upgraded handheld device that will work anywhere in the country with no additional infrastructure costs needed, so why don't we? Because they are subject to failure, that's why. I think APCO has forgotten who in the hell they're supposed to be looking out for. Do you really think these whiz bang digital systems are going to stay up and running during a major disaster? Pfft.
Just listen to the Phoenix digital feed sometime. Several times a day, a dispatcher tells a unit "please repeat, you went digital". And now we want to add TDMA to this mix? Yeah, what a great idea, that'll fix everything. :roll: These systems are a joke now, let alone in the future when we are basically giving our first responders $5000 cell phones.
-AZ
freqhopping
Lo Co VA/ FM19
Mike
There is, all units in my county are now using it.
I'm ready do some beta testing, they just got to send a scanner my way.:)
greenthumb
Colorado DB Administrator
Well, anything using 700 MHz will need to be 6.25e by 1/1/2017, which in P25 trunking will mean Phase II since no P25 FDMA solution for 6.25 kHz is being offered.
http://www.npstc.org/meetings/Rinehart - RPC 700 MHz Regulatory Update.pdf
So, the answer is seven years - at the most.
Dave1586
Southern Maryland
How? I have a 996XT and have uploaded all of the info. from Radio Ref. for PG and can't get crap! Nothing, nada.....
Any help would be appreciated
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
As mentioned in the PG thread (and in the database, and the wiki), nothing out of the box can copy the (pre) Phase 2 TDMA that system uses. It will likely take a couple of years before something comes out that can.
One possibility is to use a discriminator tap and the DSD software and that's about it. The only other possibility - and AFAIK it hasn't happened yet, but the system is just getting started being used - is if an unit affiliates with the system that can't handle TDMA - in that case, the talkgroup it's using will change over.
Sorry to be the bearer of bad news, but trust me, I'm sure other PG county scannists aren't happy about it either....73 Mike
SkipSanders
Silent Key
Uniden isn't going to develop a scanner for Phase II until there IS a Phase II to develop for.
What's currrently deployed are NOT final systems, because there is no Phase II STANDARD yet. Until there is, no scanner for it. Everything would be one-offs for individual, one-system test stuff that may, or may NOT, be compatible with whatever the actual standard ends up being.
Dewey
If your "How" question was about my post above (#10), that post was made on 12/16/2009, before the switches were thrown, and the jurisdictions could still be monitored on their "old" systems.
Dewey
KT4HX
Spotsylvania County, Va
Bingo! This Capitol Hill Monitor newsletter speaks to the PG situation, and has comments from Upman regarding the lack of a standard. http://henney.com/chm/0110/chm0110.pdf
jkahn
Very good looking Member
Silver Spring MD
Hey Paul:
You've got 3 Beta volunteers right here that have already tested the 396/996T version 3 pre-release firmwares for you. Just let us know when you are ready to send a TDMA capable scanner for us to test on Loudon & PG Counties!
As I said on the ScanDC list this morning: I have asked my buddies on local PDs that use the PGPD radio system to "accidentally" leave their radio in FDMA mode. When they are on the air and "affiliated' with the system, that forces the entire system back to FDMA until the dispatcher gets pissed and identifies the unit and tells him to go back into TDMA mode!
If I understand correctly, the PGFD will stay FDMA for some time even after all equipment has been switched over and tested because of all the volunteers who monitor like we do. There are just too many pagers and scanners for the FD to replace the volunteer force radios with TDMA capable equipment.
