P25 Threshold For Elkhart/Stjoe County
osolo58
Elkhart,Indiana
I recently brought at Uniden BCD996P2. I was wondering if anyone might have any clue in what the P25 Threshold for Elkhart County as well as St Joe County so that I can hear things a little better. At times it seems like it goes digital and I know that is a system thing and not a scanner thing that I can fix but there are times I hear things crystal clear with no issue.
Whiskey3JMC
DXpeditioner
Philly burbs 🇺🇸
Welcome to the RR forums. Counties don't have specific threshold settings, this is dependent on your location relative to two or more simulcasting towers. What you are experiencing is a phenomenon well discussed on the forums known as simulcast distortion. The scanner may decode fine in one area some refer to as a "sweet spot" but move it around somewhere else and you may lose the decode. You can try the mitigation methods in the wiki I linked, they may or may not work. Ultimately you'd be better off with an SDS100 or SDS200 if this is a system you intend on listening to frequently
osolo58
Elkhart,Indiana
Thank you for the quick response. As well and the knowledge
