Is there some way to make a permanent adjustment to the P25 threshold setting on the BCD325P2? I know how to change it, turning it on holding the "Hold" button, then in settings making the adjustment, but once you turn it off, it defaults back to Auto again next time you power up. Is the only answer that you sign on each time wth "Hold"? Why doesn't it save the adjustment to memory? I could not find a way to make a system change in any of the supporting software (as is e case with Sentinel and the 436HP) or am I missing something?
Any help would be appreciated.
