P25RX Firmware Updates / Testing
Cheeseburgers
Yep, did it exactly as you instructed. Always error when "discovering device" upon the final power cycle after the firmware install. Tried it on 3 different machines always the same.
btt
Banned
Banned
Wa State
The recovery firmware erases the flash memory (takes a few seconds), then turns the leds on. It doesn't do anything after that. You should be able to cycle the power and load firmware after that. Did you try loading firmware prior to the recent releases? It doesn't really make sense that there would be an issue, since the bootloader hasn't changed. Send me an email if you would like to send the receiver back for inspection / return.
btt
Banned
Banned
Wa State
Could the bootloader have been damaged?
In theory, it shouldn't be possible. It is "write protected" in the MCU. If you are still able to transfer firmware images, then I don't think it is the bootloader. I'm going to send another DM with an alternate version of the recovery firmware that erases flash in a different order. Give that a try. Same thing, load it, wait for the leds to turn on. After that, cycle power and load firmware as normal.
nosig55
NEKS/NWMO & SWMO
I loaded 2021-03-08_0546 at about 08:00 CST this morning and it ran ok until about 10:00 CST. Then it quit RX and had to restart. SIG & TG light lit but no audio. Running on a win 10 desktop through pc speakers. Audio was good and clear up until it quit.
Previous 2021-02-24_1047 had been running 24/7 no problems.
  • Like
Reactions: btt
btt
Banned
Banned
Wa State
Thanks for the report. Sounds like I still have work to do.
-edit: I had an idea of what might be causing that. New testing version available. 2021-03-08_0847
btt
Banned
Banned
Wa State
OK, Loaded 2021-03-08_0847. Thanks for your fast support Todd !
I had _0847 USB lock up. I think I know why now. There is a new version with another attempt to fix that issue: 2021-03-08_0948. This version also changes the way that phase II audio is buffered. Let me know if this change is no good, so I can put it back the way it was.
rdlafore
Acworth GA
Running 0948 now, but just a few minutes into it. 0847 did OK here, until it was replaced. I am running the USB-PC audio and an external speaker on the P25RX, so far so good.
  • Like
Reactions: btt
btt
Banned
Banned
Wa State
Had _0948 lock up. I found something else to try. On version 03-08_1119 now.
btt
Banned
Banned
Wa State
_1635 USB lock-up here too. I should note that the receiver does continue to run and work with Bluetooth / line-out. I'll keep looking. I really don't want to revert all these changes. It is working great while it works.
-edit: I put the link to 02-24_1047 back up as the "stable" version. I found something else related to USB. Starting to test 03-08_1938
