Cheeseburgers
- Joined
- Jan 9, 2018
- Messages
- 632
If you are still available for testing today, would you mind trying _1306 testing and see if the choppy audio issue returns? I would like to try what should be a universal way to handle the issue.Seems much better Todd!
Also. anybody else in CT using one of these?
Since it is an issue with BTConfig only, I made some more changes to BTConfig audio (version _1516). I did notice the audio from BTConfig was not as good as the line out. It sounds good now. (only tested on Linux so far).BT Config only, and I should have clarified - I do not have a P1 to test, so just P2.
Thank you for testing _1306. If you do test _1516, let me know if you find that it is a step in the wrong direction, and I will revert back to _1306. Thank you for reporting on P2 TG interrupt. That is the first I've heard anything on that. I'm glad to hear it is working so far. It is a great feature to have an "embedded control channel" contained within the voice channels. I knew this was the case with P2, but I didn't realize that was the case with P1 until somewhat recently.I am using 1306 on the same system as Cheeseburgers. I have had no issues with the choppy audio on Phase 2 using BTConfig audio. The priority function works good, although I havent had many times when it has kicked in yet.
What Site / Where ?I am using 1306 on the same system as Cheeseburgers. I have had no issues with the choppy audio on Phase 2 using BTConfig audio. The priority function works good, although I havent had many times when it has kicked in yet.
Can you let me know the first version after 4/2/0803 that had issues for you? There have been a lot of changes since 4/2.All the firmware updates after 4/2/0803 have had choppy audio on phase 1 transmissions. It's not always choppy though. The blks per second will drop off abrubtly then go back up. It doesn't do that with the 4/2 firmware.
