Todd - a suggestion -
When looking at the Advanced tab the selection for the MCU clock speed with the dropdown choices always shows the default of 400 MHz whenever the program is restarted. But that does not reflect the actual set clock speed, at least in my case. I now have it set for 480 MHz (confirmed with the console command mcu_speed) but the setting in the Advanced panel still shows 400 MHz.
I think there should be either a seperate window showing "Current Set MCU Clock Speed" or the dropdown window should be updated to show what the actual setting is currently at. Otherwise, I can see this causing confusion with users in the future who may not be aware of this and did not check their actual clock speed with the mcu_speed console command before reporting issues to you.
-Mike
