P25RX-II P25RX-II Firmware Updates / Testing
btt
Banned
Banned
Wa State
Anyone else having issues with P25 P2 and version 02-25_2250? Looks like it may not be ready to ship yet based on @freqseeker's testing.
pcman67
Radio and electronics enthusiast since the ‘70’s
Florida
@btt, I’ve not had time to test this version but plan to do so later today and I’ll post my results here.
btt
Banned
Banned
Wa State
Thank you! You may want to wait for another update. There is still an issue I'm trying to hunt down. I will update this thread when I think it is fixed.
shirsch101
West Chester, PA
Using Rev 2202-02-26 09-06 This sounds great!!! Question...on the Search DB Tab what is the Monitor Selected button used for?
btt
Banned
Banned
Wa State
I think the issues for the latest testing release have been found (at least a few of them). Please continue testing with version 02-26_1124. Thanks!
If you have roaming disabled, then you can select a row in the table and press monitor. That will switch to the selected frequency. There are also new next / previous frequency arrows that can be used to cycle through the frequencies stored in the roaming flash (when the roaming mode is disabled). There is also a quick <R> button. This enables/disables roaming mode temporarily (unless the configuration is saved).
btt
Banned
Banned
Wa State
This appears to be fixed on my end. Excellent audio and switching between CC and Voice channel.
Thanks.
Thank you for all the testing! There is another update with some improvements related to roaming/scanning multiple cc's with the timeout set to 0 (CC busy status). Version 02-26_1228.
cheif
redford mi
I have been testing the last release 12:28 and run into this. When tested selected frequency shows info but also down lower left tested 0 frequency and found 0 P25cc. When I write to flash it locks up. After restart I clear everything and write to roaming flash this is what comes up no complete information. It works great and sounds great. Thanks for the great job your doing.
P.S. photos to large to send.
bagmouse7
NC, USA
The 2-26-1228 version seems to work correctly and the audio sounds great, except the "SIG" status light never turns green?
The signal is good and strong and this indicator always lit up in previous versions....
Thanks!
btt
Banned
Banned
Wa State
Thank you for testing and the email. I'll keep working on it.
Thanks!
Thank you. Can you check on the P25RX Config tab and make sure that the <Enable Status LEDs> option is enabled? The SIG indicator should mirror the actual hardware led.
bagmouse7
NC, USA
Ok, I just checked and the "Enable Status LEDS" was not checked.
Checking it does turn on the SIG led in the GUI.
This behavior seems to have changed in this latest 2-26 version. In previous versions I had it unchecked and the SIG indicator in the GUI was always on when the radio locked onto the control channel.
Can you maybe add a "Enable GUI status LEDs" check box to the config page?
I prefer to keep the LEDs on the actual P25RX unit disabled, but I like to see the SIG indicator green in the GUI.
Even with the "Enable GUI status LEDs" check box disabled, the yellow "TG" indicator in the GUI still lights up when voice traffic is detected.
Which is why I expected the SIG indicator to light in the GUI.
I think enabling/disabling the GUI indicators separately from the hardware LEDs is a better way to do it...
Thanks!
radio3353
Same behavior in the P25RX GUI. I have Enable Status LEDS off, but the SIG indicator is lit up in green.
raidamation
Todd, great work as always. One minor bug. When using with my Wio and receiving a voice channel the frequency changes to all zero's. CC is okay.
btt
Banned
Banned
Wa State
Thanks!
I'll add an option for this. Thanks for the feedback.
btt
Banned
Banned
Wa State
New version available. 2022-02-27_0451.
Thanks!
The SIG status led now works like the status line on the signal insights tab.
This issue is fixed in 02-27_0451. Thanks!
bagmouse7
NC, USA
Fantastic!
You actually made it even better, now it goes green-->yellow following the sync state!
One more request..
Can you add a $TG_DESCRIPTION$ field to the display view options?
I didn't see it in the list an I would like to display the description field in addition to the $TG_NAME$ field.
Thanks!
