Quick feedback and two questions.
Ran 2022-07-03 14:40 over the weekend on the 700mhz Boston overlay of the CoMIRS system. This is a mixed Ph1 (FDMA) + Ph2 (TDMA) system, which was very busy with 4th of July activities. Even though I am at the edge of reception all worked great including decode of Ph1 voice and the limited non-encrypted TDMA voice calls. Ran 36 hours straight on Win10 box with no lockups. Great work.
I also tested on a conventional P25 LSM system with great results.
One noted glitch, it appears audio recording is not working with P25 conventional. Works fine with analog and P25 trunked.
First question: On trunked P25 system, will voice channels inherit gains of the control channel--that is, I only program the CC and set manual gains for best reception; do I need to also enter the VC for the system and manually enter the gain that works best for the CC?
Second question: Is there any way to change the name of a frequency in the system tree if I initially incorrectly enter the frequency. For example, if I initially enter a frequency of 700.58125 but find it to be incorrect, I can change the frequency to the correct 774.58125 but the label in the system tree remains 700.58125 and I can't see how to change it.
Thanks for all the great work.
