I've been testing 28_2356 for about an hour now.
Still bad with the "mixed up" or "interfering" talk groups, at least using the default of 250 ms for the rf_sig_to setting.
It's pretty obvious now and weird - you might be listening to a PD manhunt and in the middle of the conversation in pops some traffic from a public works group about moving trucks around:-0!
And the other way around too...would be kinda comical if it weren't for the desired operation being impaired!
Also lots of cases of fire traffic suddenly coming over PD and Sheriff's groups and vice versa, etc.
I have noticed that this problem seems worse on one site versus another.
I monitor a very large county system with a lot of simulcast sites.
I am in range of two sites - West and North. At this time, early morning, North is not as busy as West. That seems to change over the course of the day. But, for now, seems like I have a major issue with the West site with this problem while not nearly as much with the North site.
From my location with my inside antenna, North is the stronger of the two in the -75 dBm range but West is not horribly low - in the -90 dBm range. Audio sounds really good on both sites.
Also, the West site seems to have more P2 traffic than the North site. So maybe an issue with a "mixed" system, P1 and P2 traffic?
I just tried setting the rf_sig_to to 50 to see if that helps.
Also set the Talk Group Timeout to 5 seconds now that that is available.
Still happens, sorry to say, on the West site. Those busy PW or road workers or whatever keep popping in to PD and Sheriffs traffic at the weirdest times! Like I said - would be funny but...
It's obvious the actual subscribers are not having this problem or they would certainly be mentioning it themselves.
I think has been happening for a while - for quite some time I was hearing a lot of traffic on a "Training" talk group such that I, at first, thought it was being repurposed as a different use. But then I noticed that the traffic was all over the place - snippets from many different groups. It got so annoying that I de-selected it. I think it was just a "quiet" little used talk group and this issue caused it to "collect" a lot of bits and pieces of traffic.
Anyway, yeah - definitely still a big issue for me, unfortunately, even with the rf_sig_to set to 50 ms. Guess I could try increasing the time beyond the default 250 ms but I would think that would make it worse. May try anyway.
I don't think there would be any point to sending logs as they wouldn't show anything - you have to know the system and hear the audio while seeing the displayed talk groups. Sometimes it's super obvious with just the audio, though, as mentioned above...could be hearing a tense situation on a PD talk group discussing a manhunt and all of a sudden a discussion about where to send the dump trucks pops in!
But the audio does SOUND good, at least through the line out. Have never tried the Bluetooth yet.
-Mike
