... I have wired earbuds which work okay, but the volume is low. A wired external speaker I tried had audio so low as to be unusable.
Maybe I need more detailed paring instructions.
Regarding U-Connect, I do have it listed as one of the two known devices that are reported not to work in the user-manual... If someone out there is familiar with 'C' and Bluetooth code, I'm willing to share source code if you want to take a shot at getting it to work. (send me a direct mail to discuss).
That is good news!, but I do recall someone previously in the thread couldn't get U-connect 8.4 to work. I will change the user manual to "may work".I believe I have U-Connect 8.4 (can't see where to see the version) so it does work audio-wise. I can't help with code....I am familiar with C as the third letter of the alphabet and that's where my skill ends...![]()
Correct me if I'm wrong, but isn't the analog audio output a "Line" output? A line output is, by nature, not designed to drive a headphone, let alone a full size speaker. It's designed to drive the input of another amplifier or mixer, recorder, etc. To drive a speaker you would need an external amplifier, same with a headphone. Also it's designed to drive an input impedance of around 10K ohms not the 4 to 36 ohms typically encountered with speakers and headphones.
I would use powered speakers or use a small amplifier.
Line level audio: Line level - Wikipedia.
-Mike
For the wired earbuds you need an external headphone amp. Here's a portable one on Amazon: https://www.amazon.com/Headphone-Am...ble+headphone+amplifier&qid=1602169172&sr=8-3.I have a cheap Bluetooth earpiece which I have been unable to pair successfully with P25RX. I have wired earbuds which work okay, but the volume is low. A wired external speaker I tried had audio so low as to be unusable.
This is where the commands that haven't made it to the user manual are posted: P25RX Tips And TricksI looked through this growing thread to see if there's a list of console commands in one place. Did I miss it?
Ok, thanks. I've been using those. I wondered whether there were more.This is where the commands that haven't made it to the user manual are posted: P25RX Tips And Tricks
I'll work on documenting some more commands. You can see a few more if you do a '?' followed by 'enter' in the console.Ok, thanks. I've been using those. I wondered whether there were more.
Hi Gang. I received my unit today; the signal strength is very weak compared to my SDS-100 (10dBm difference with the SDS winning) and audio on voice channels is quite choppy, resembling Simulcast Distortion issues of the past. I feel like I'm doing something wrong. I started with 10-2 then switched to 10-8, which was a little better. Any suggestions? I'm already using the upgraded antenna the unit came with.
*On a voice channel (same frequency) the SDS-100 is at 50db and the P25RX is at 89db. The radios are right next to each other and the P25RX is using the good Remtronix 800Mhz antenna. This concerns me that the P25RX receiver is in some sort of attenuation mode.
39dB difference between the two definitely doesn't sound right. I can say it was tested with a signal generator before it was shipped and it is doubtful that it quit working during shipping. When the input signal from the antenna is at -89 dBm, you should be seeing a "fonrt-end RF gain" of 38 dB. Is that what it is showing?
Could you post a representative screenshot of the I/Q symbol plot?
[edit]
If you aren't able to figure out anything, please contact me via e-mail. It may be that something did happen in shipping.
