Question: I was experimenting with various inside and outside antennas to test the effects on reception. When using a particular 800MHz band outside antenna (on an 800MHz trunking system), I was seeing four bars on the RF Sig Level meter, and -85 dBm, but the SIG light was not lit, and I got poor or no decoding. But when I changed to a different antenna, I got only one to one and a half signal bars, -103 dBm, but the SIG light was green, and I got good decoding. Could this be an overloading issue with the first antenna?
The LNA has an OIP3 of +40dBm, so it probably isn't an issue with that. It is possible that it is a nearby blocker. There is one person who reported experiencing this when in close proximity to some cell phone towers (where I assume the cell tower frequency was close to the control channel frequency). In that case, he reported that a 10dB attenuator helped. There are some blocking specs in the user manual.
[edit]
Another thing to look at in order to determine if you are receiving a good signal level, is 1) Look at the I/Q Symbol Plot. If there is a pattern with four distinct areas of symbols in the 4 quadrants of the plot, then you are receiving a good signal with symbol synchronization. 2) If the I/Q Plot looks ok, but you are not seeing a SIG led / TSBK/sec >0, then you should check to see that your reference frequency is correct. Is the reference frequency estimate showing in green/yellow/white in the Signal Insights tab? If it is showing red, then try to use the estimate to program your reference frequency. If the reference frequency is too far off, then the decoded symbols may be incorrect.
