HI BTT: My measurements current stable FW to 10-10.0651:
First, I confirmed good signal strength on all of these an another receiver. The antenna for that receiver is about 10 feet higher, but it let me know that I could copy the signal at reasonable strengths. Each of these is S9+ on a IC-706MKIIG, so I verified each was audible at good strength from my location. The P25RX was connected to a Diamond Discone at 35 feet, and I am at just short of 600 feet ASL up on a ridge. All of these are VA STARS control channels:
Frequency and signal on stable FW and new FW:
152.2025 -89 dbm/-93 dbm
151.070 -112dbm (no sig)/-117 dbm (note: S9+ on other receiver/antenna as well as SDS200 with whip on back)
151.3925 -77 dbm/-81 dbm
152.5475 -78 dbm/-83 dbm
As you can see, all lost signal, which wasn't good to begin with, with the new FW. I could decode with both, but signal strengths were lower.
Also, as a side note, the software does not ouput audio to PC when in FM mode, so I had to attach as separate amplified speaker to listen to the audio when monitoring the P25 CC directly.
Thanks.
