Blue Tail Technologies P25RX P25 Phase 1/2/DMR Receiver With Bluetooth Audio Support
cmjonesinc
@btt Pure curiosity here... Do you happen to know what the amperage requirements are for one unit? Trying to do some port consolidation.
yodermans
Hello all
I am working with my p25rx and cant seem to get the priority's working attached is my talk groups file
icemantim8
Colorado
Very reluctantly selling my unit to generate some cash flow after major surgery :( Listed in RR Classifieds........
btt
Wa State
No sir never have
What is the Talk Group Timeout set to? You might try setting this higher. That should cause the priority decision to happen more often.
Sorry to hear icemantim8. Best wishes.
btt
Wa State
I have tried all the setting from 100 ms to 5 sec and nothing showing up with Tg Pri
What version are you using? The first version that output the (TG PRI) to the talk group log was version: 2020-11-14_1212
yodermans
11-26-1529
I haven’t had it work since I had it several versions back that why I was asking about the command to show the talk groups that was assigned priority I have also tried just leaving it on one control channel to see if that made a difference I have was also done factory reset with no luck
btt
Wa State
11-26-1529
I should have noticed the software date on the image you posted earlier. I'm not sure why it is not working for you. I'm testing here with a very similar configuration to yours. It appears to be working good. (default 2 second talk group timeout). I will continue to search for a possible solution.
yodermans
Wonder if I should factory reset and re enter the talk groups from scratch cause I am using my talk group from my original build
btt
Wa State
I don't think that will help. I found a case in the firmware where the (TG PRI) string was not being added to the log when it should be. Try version 2020-11-29_0307.
yodermans
Good Moring Sir
I have done the firmware update it is now showing the (TG PRI) but not ever time the talk group is shown I have to talk group time out set to 3 sec. Also it not interrupting the talk it is currently on for the one that is set for Priority
  • Like
Reactions: btt
btt
Wa State
When will the P25RX units be back in stock?
Hope to have a few ready this afternoon.
Good Moring Sir
The (TG PRI) will only show up if the current talk group being held (in this case for the 3 second period) is interrupted by a higher priority talk group within the 3 second period. The interrupt only happens at the time of the channel grant. In other words, the receiver has to return to the control channel due to an "end of call" message or timeout on the voice channel before the channel grant will be processed.
yodermans
Ok thanks and thanks again for your hard work
