the "write congfig" is grayed out
BTT: What is the data format of the TGP files created when we back up Talkgroups, and are they directly editable?
Edit: also, when you go to save a set of Talkgroups, the dialog box name is "Open", which is a bit confusing. I can see by the result that I am saving the TGs to a new filename, but it would be better named "Save as" instead of "Open".
Thanks.
const char [] = {"TALK"}; //first 32-bits
int number_of_records; //next 32-bits
//TG records * nrecords
typedef struct {
uint32_t enabled;
uint32_t sys_id;
uint32_t priority;
uint32_t talkgroup;
char desc[32];
char location[32];
} tgrecord;
I've seen and experienced this a number of times but, as I have a number of things that use the USB ports that I am frequently disconnecting and reconnecting and a lot of experience with computer issues including USB-related ones I just automatically go into the "shut down software, disconnect device, restart software, reconnect device" two-step tango mode which usually solves the problem. This with a Windows 10 PC, btw.btt,
whatnI start the BTconfig, I get "Status: discovering device. Please wait" tha P25RX never connects. What does this mean? The only way to connect is I have to unplug the usb cable.
Currently, I'm not familiar with unitrunker or Uniden Home Patrol, but I will do my best to review them and provide the same information.
Thanks for the link. It appears that backlighting is not adjustable. The controller supports it, but the implementation is on/off only.Color display sounds nice. Adjustable backlighting? Would be nice to have in a mobile environment.
I've been thinking about this today. I'll do my best to get a csv type export / import working this week. For now, I think I will implement the import to use the first line of the text file to define the column names and order. This way you should be able to take your existing csv files and stick a one line header in there before import. First, I need to assemble and test some more P25RX units.BTT: What is the data format of the TGP files created when we back up Talkgroups, and are they directly editable?
Tried 10-26-0928 FW (with advanced Tab) and it's not working right for me. Initial roaming after a single transmission results in an audio thunk that continues at about a 1 cycle per second rate until another voice transmission, when it stops for the duration, but continues again once roaming starts. Very annoying, and it doesn't appear to be related to a frequency in particular. Have reverted back to 10-22 FW.
The firmware is only updated if the firmware version changes. (almost always). There is also an internal configuration version. If the configuration version changes, then all configuration options (except for a few, like frequency) are reset to default values. This makes it very easy to upgrade or downgrade the software to any version.So, each time a new version of the BT Config software is used, it performs a firmware update to the device?
