P25T Digital Address
billyfromhill
What is the "P25T Digital Address" column on tab D5? I'm trying to get Call Alerts working via a 7 digit P25 ID, I believe Unication calls this the "SUID". Is this just a standard P25 call alert that can be transmitted from a mobile or portable or certain consoles?
Also, is there any way to alert a group of pagers via P25 ID? I don't want to have to transmit 30 different call alerts to 30 different IDs any time I want to send a page. Do I just program all the pagers with the same 7 digit SUID? I can only add one SUID and I would like to page just groups of pagers without having to transmit more than one call alert.
How are the IDs set? Obviously the pager doesn't affiliate with the system. Can I just use any 7 digit number? Should I try to avoid IDs that are assigned to subscribers on the system?
2wayfreq
NM Kirk City
I know from an indication standpoint, this shows when two or more talk groups are being patched.
billyfromhill
So I have gotten this working. The SUID under Private Call is the P25 ID you want it to alert to. I transmit a Call Alert from an APX portable to the SUID of the pager and it alerts. You must enable the Call Alert Radio Service in tab D7 of the pager.
KJ4NFP
Richmond, VA
I am also working on this for a system I am deploying. Am I understanding correctly that if I assign the Unit ID in the private call area and then enable the call alert function, this will alert? Do I need to assign it in any zones or is is independent of whatever the unit is scanning as long as it is on the trunking system that will call it? I am assuming an individual call from another radio or console would light it off as well.
billyfromhill
Yes, as long as it is bound to the talkgroups in your knob positions the pager will alert. The pager needs to be on the same site as the radio sending the call alert, but there does not have to be a radio affiliated with the ID of the pager. You want to transmit a call alert to the ID of the pager, not a private call.
