P5300 Programming Issue
grem467
Houston, TX
I have a 900MHz P5300 with R14 firmware that i cannot read. It will not even go to program mode (PTT while turning on) nor bootapp (all three while turning on)
I am using RPM 8, and the ca-023407-003 rev b cable under windows XP
Any ideas?
SuperPhly
Is there any indication that the PTT button isn't working? I haven't had the problem with the 5000 series, but when it happens with the 7100s I have to pop the plastic exterior button off and push in on the rubber piece to get it to go into programming mode, and then subsequently replace the button.
SuperPhly
Hm, check all the menus? I was working on a 5400 once that had an option within the menus to go into programming mode. That's all I got on the topic. I don't have very many 5000's in the fleet and they rarely have any problems.
Cheesedoff
Is it booting to ECP or OTP?
Also on the later series you need a real programing cable as rpm automatically puts it into programing mode. If the cable is hooked up you can put the radio into program mode with the ptt and 2 side buttons well turning the radio on like the older p7100s used to. Make sure your in ecp first though.
Texas
The cable you are using isn't a programming cable (that is what the 003 means, I think it's a key loader cable). This is probably why it isn't going into program mode when you power on with the PTT pressed and the cable connected.
R14 supports automatic program mode, so if you don't have data selected, just connecting the cable and setting RPM off should switch it into program mode. If that fails, you're going to have to either modify the cable to have a 0ohm sense resistor, or get a real programming cable.
