Is it normal operation for 'P7000' series radios with adjustable backlighting settings to jump to full brightness when a talkgroup is active and the setting is below 6?
Is there any known issue with the backlighting function when Enhanced CC scan is set for a system in the radio? I have a P7100 that when it's set to the system programmed for Enhanced CC scan,the backlight will continuously turn on and off without touching any of the radio controls.If I set the radio to any other system programmed into the radio the backlight functions as normal and doesn't come on until you touch one of the radio controls.
