P7100 work on Simulcast Systems?
TDR-94
Can a P7100 be programmed to work on a Harris GPS simulcast system with multiple cells? From what I gathered the P7100 only lists C4FM for P25 modulation according to the data sheet.Harris Simulcast Systems seem to use WQSPK modulation.Later Harris radio models like P7200 and newer list both for P25 modulation.
Would it even be able to demodulate WQSPK?
TDR-94
Can a P7100 be programmed to work on a Harris GPS simulcast system with multiple cells? From what I gathered the P7100 only lists C4FM for P25 modulation according to the data sheet.Harris Simulcast Systems seem to use WCQPSK modulation.Later Harris radio models like P7200 and newer list both for P25 modulation.
Would it even be able to demodulate WCQPSK?
It should be WCQPSK not WQSPK. Tried to edit but won't allow now.They apparently also offered EDACSIP GPS simulcast systems from what I saw on one of their brochures.
Seems the P7100 may not be able to properly receive on a P25 simulcast system after finding this if all it can demodulate is C4FM.
'Digital Simulcasting'
"To add to your list of acronyms, there is another type of modulation scheme that's used with some multi-site Project 25 systems. Linear Simulcast Modulation (LSM) is a trademarked term for a form of CQPSK that provides a way for receivers to properly handle multiple identical transmissions. It's just different enough that the regular C4FM processing doesn't work correctly."
Radioman96p71
I have several and they work just fine on RX. TX may be another story. Just make sure they Ref Osc is set to a known good source so its freq is accurate.
TDR-94
As long as it works on the RX side that's works for me.I was wondering if it was more of an issue trying to TX,but not concerned about that for my needs.
