P7200 Adjust Audio Treble Level
kg4frf
Merritt Island, Florida
I read thread: "Taming the Tinny Sound of a Jag 700P", and it referred to Audio Level Equalization, however that option doesn't work on the P7200. I found in the Rev.f of the P7200 User Manual, Section 8.21 Adjust Audio Treble Level. It refers to a 'Treble Menu' which I can't find in RPM. It's called out a couple of times in the User Manual. My P7200 has that "tinny" sound and that treble level menu sounds like the fix, without a hardware mod. Can you RPM experts help me out, thanks in advance.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
The BEST way to fix the poor audio quality of the P7100/P7200/P5100 series radios is to do this:
Remove the front cover from the radio.
Carefully pry the speaker out of the cover.
Get some ordinary electrical tape. 3/4 inch wide regular stuff.
Cut two pieces of electrical tape that are a bit shorter than the width of the speaker cone.
Apply these two pieces of tape to the face of the speaker in an X configuration.
Carefully reinstall the speaker using silicone adhesive. Be sure that you put it in in the same
orientation it came out.
Reassemble the radio.
Enjoy a considerable improvement in audio quality.
This does a lot more to improve audio quality than any softare adjustment.
Forts
Mentor
Ontario, Canada
I took a stab at this today but couldn't get the spanner nuts off from the volume and channel selector. Didn't really want to force it and break anything so I left it be. Need to find a proper tool for removing them.
Radioman96p71
You don't need to remove the knobs at all to take the top cover off. The back plate pops off if you pry gently where the battery detent is on the back, under the 'hump'. From there it pulls up and over the knobs revealing the last 2 screws under it.
Forts
Mentor
Ontario, Canada
I couldn't get the cover apart. Took out the 6 screws in the battery compartment, then one under the foot of the belt clip. The bottom part of the radio would open up OK but I couldn't get the top to separate and I didn't want to force it. I'll take another look at it tomorrow.
FDRadioguy777
There are approximately 8 screws to release the front cover. Did you unscrew the two at the very top under the back cover?
Forts
Mentor
Ontario, Canada
No I didn't get the back cover off... That's where I stopped. Thanks for the tips, I'll take another look at it.
FDRadioguy777
There is a little screw where the belt clip goes. That is what releases the back cover then you can pry that off and under it will be the last two screws.
Forts
Mentor
Ontario, Canada
Finally got around to opening the radio to today and installing the tape. Wow what a difference! Audio much more pleasant sounding and a lot less shrill.
