P7200 - Static Bursts/Tone not Decoding?
ScubaJungle
West Central Florida
I recently got some extra surplus radios as I wanted something capable of 700mhz.
Two were P7200s - one was completely wiped of all firmware. They ended up both programming fine after new firmware/dsp, but they both get these immensely annoying bursts of "static" which is the "tone" that is played prior to a fire/emergency call, I guess not decoding properly (I assume - when I have another radio/scanner on simultaneously, I hear the tone, but on these, its loud static). This is on an EDACS system.
This doesn't happen in any of the other radios, including Jaguar 700Ps and P7100ips with the same exact personalities in them.
The feature list is:
01 04 05 06 07 08 09 10 12 21 22 23 29 33 39
The only feature that the P7200s dont have, that the others do, is 14, which I cant see how would have any effect on this.
TL;DR
As I said, when I have two radios next to each other (P7200 & 700/P7100), one plays the "tone" correctly (which sounds like a short control channel burst, if you arent familiar with EDACS), and the P7200 just bursts with static.
Ive tried simple things like squelch and data is off, with no change, so I dont know what this is.
ScubaJungle
Nope, no CC Scan, it's not having any trouble with that (or doesn't appear to, anyway). The tone varies in length, usually it is 1-2 seconds, but sometimes lasts longer (~5 seconds). The only way I can describe the tone without referencing EDACS is the buzzer at the end of a basketball game. This usually goes on before / after a fire call, and it may even be manually done by a dispatcher since the length varies.
Ill try to get a video/recording of it.
ScubaJungle
Let's see if this works, I'm having trouble finding hosting for the video:
The p7200 w static:
Jaguar with tone:
The tone you hear on the Jaguar is one of the tones, the other one sounds more like a buzzer but Ive been unable to grab it today. This gives you an idea of what I mean though.
ScubaJungle
SOrry about that - hopefully this works
That is only one of the tones though - I havent been able to catch the other, but its a buzzing sound like the end of a basketball game
