P7300 Issue
txrxaz
Have a question. Have P7300 Harris. Screen message: READY:MBAPP,also READY: ECP.I was trying to read Features,and this message showed.How to get back to normal function of radio.Do you know how to Exit this message,back to normal operation?Thanks.
N4VGW
Rustburg, Virginia
To get out of BurnApp Mode:
1. Press the down arrow, display will read M:BAPP. Select to load.
2. Press the Opt1 button, display will read M:ECP. Select to load.
3. Press the Menu button, display will read M:ECP. Confirm? N
4. Press the Opt1 button, display will read M:ECP. Confirm? Y
5. Press the Menu button. The radio should reboot to its normal mode.
Raynorshines
So to enter the option mode, any suggestions.? I want to see if mine has option 47, TDMA 2
Raynorshines
Nope... same thing I have been getting.
Menu/Scroll ↓ =Radio ID ↓ = Dear of Manufacture ↓ = HW Rev A ↓ =Band 7/800 ↓ =AES Ver ↓ = DES Ver ↓ = DSP Feat ↓ = 06EF ↓ = DSP Date ↓ = DSP Time ↓ = DSP Ver V16.13 ↓ = BLD Date ↓ = BLD Time ↓ = Flash Ver R16A18 ↓ = Pers Ver 67.00 ↓ = Persnlty AHS4914P ↓ = Radio ID ↓ = Harris (C) 2012 ↓ and then it repeats.
I have tried holding some of the other keys down when scrolling and or hitting the menu key without any difference other than stalling.
Forts
Ontario, Canada
You're in the Revision menu, not Features. As Elroy mentioned about, it's not something that's there by default. In RPM you have to add it under Options - Programmable Menus
