overtheair
System in question Durham Prime Site Site Details (Durham-Fayetteville)
Radio works perfectly fine when programmed as a receive only p25 trunk. I used the personality I have in my p7100 converted to p7300 loaded it in and works fine.
The problem is, i still get analog transmissionsand no p25 transmissions which could be 2 different issues. When the radio is turned on the call guard icon is there along with 25. I am wondering 1, why analog is still getting through(even after changing dpl several times) and 2, if using the site nac(5C2) is not having the effect I am wanting with SEL sq mode to filter out talkgroups aside POLICE A.
While writing this, I did pick up the group a few times(the correct one). Apparently it is un-muting on analog so much I am missing what I am after.
This is just a demo for a friend at work. The tower I am going to do this demo is out of range, so I am trying to get this to work on the Durham system prior to programming the other the same way.
See images below.
Thanks in advanced.
*ptt disabled
**programming the other system in the radios for non-affiliate is a different issue I have encountered and will take that up in that relevant forum, which is why I am doing it as posted above.
***I am saving up for a sds200
****the radio could possibly be slightly out of alignment. When the Durham system is programmed in as a trunk system, it takes about 5 seconds to lock on the system over the ~1 second my p7100 does.
See images below.
Thanks in advanced.
*ptt disabled
