PA DOC Digital??
kkr8558
BCD325P2
Mechanicsburg, PA
Just wondering if anyone knows anything about the state prison system converting over to a digital system? I've noticed a lot of the Eastern prisons aren't being received and when you take out the PL tone, all you hear is digital noise. I was recently in Centre County and Benner can still be heard, but Houtzdale appears to be digital. Can anyone weigh in on this.
n3obl
Ø
PA
one facility is noted to be using trbo so it would not be a stretch to think possible switch to DMR.
kkr8558
BCD325P2
Mechanicsburg, PA
The DOC is listed as having talkgroups under PA StarNet. Not sure if this is all inclusive for DOC or if it possibly the digital system they are transitioning to, but all TGs appear to be full-time encrypted.
So, those talk groups at Waymart have been like that for years. This is something that has been taking place in the last 3-5 months. I live outside Harrisburg, and as of mid-August, Camp Hill went silent. I've seen some pages indicate some PA STARNet testing, see Pennsylvania Statewide Radio Network (PA-STARNet) Radio and Unit IDs and Pennsylvania Statewide Radio Network (PA-STARNet) Talkgroup Research, but can't figure out if they are using their existing frequencies as part of the network (which would make sense since they are emitting a digital signal now) or if they are using pre-established PA STARNet frequencies.
kkr8558
BCD325P2
Mechanicsburg, PA
So, this was done shortly after the facility opened. What I am talking about is something that has been taking place in the last 3-5 months. I live outside Harrisburg, and as of mid-August, Camp Hill went silent. I've seen some pages indicate some PA STARNet testing, see Pennsylvania Statewide Radio Network (PA-STARNet) Radio and Unit IDs and Pennsylvania Statewide Radio Network (PA-STARNet) Talkgroup Research, but can't figure out if they are using their existing frequencies as part of the network (which would make sense since they are emitting a digital signal now) or if they are using pre-established PA STARNet frequencies.
kkr8558
BCD325P2
Mechanicsburg, PA
Just wanted to follow up on this thread with some updates. At least at the Camp Hill site, they have switched to DMR from NFM. So n3obl, you were tracking right.
druhe
Southwest Pa
Are they in the clear or encrypted ?
kkr8558
BCD325P2
Mechanicsburg, PA
The are clear. It seems as if they are taking advantage of the slot option, cause the main Maintenance channel is SL 1, and yesterday they went to "channel 4" and it was on SL 2. I haven't been able to analyze the Ops channel as much.
HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
DOC has been switching "inside" radios over to DMR. "Outside" radios are on STARNET. Outside would be radios used by transports, roving security, work details, etc. Inside is the unit guards, food services, etc within the facility.
Anybody who finds new dmr in use, please submit info to update the database.
kkr8558
BCD325P2
Mechanicsburg, PA
I did submit them and they are currently pending. But for information, here they are:
453.325 WQDW272 RM CC 3 TG* SL* SCI Camp Hill SCI Camp Hill - Operations DMR Corrections
453.875 WQDW272 RM CC 5 TG* SL1 SCI Camp Hill SCI Camp Hill - Maintenance CH 3 DMR Corrections
453.875 WQDW272 RM CC 5 TG* SL2 SCI Camp Hill SCI Camp Hill - Maintenance CH 4 DMR Corrections
@HM1529 Does it look accurate? It's what my scanner shows, but I'm not always sure if it's DMR conventional or DMR trunked. Do you know much about DMR? It all new to me.
HM1529
Honestly, it could go either way. SCI Phoenix is TRBO Capacity Plus system while SCI Chester was reported as conventional DMR.
kkr8558
BCD325P2
Mechanicsburg, PA
How can I tell the difference between conventional DMR and TRBO Capacity Plus system? I'm currently working with another member about how they should be posted for local businesses but they are new to both of us.
kkr8558
BCD325P2
Mechanicsburg, PA
@HM1529 In follow up and if you can, check out how he listed the business we added for Cumberland County. I think this is more on point on how other listings are similarly listed.
kkr8558
BCD325P2
Mechanicsburg, PA
In follow up to this, here are 3 more updated frequencies locations for the state prison system.
453.2875WNIJ391BCSQSCI DAL PerimeterSCI Dallas Perimeter AlarmFMNCorrections
453.325WNIJ391RM82.5 PLSCI DAL OpsSCI Dallas OperationsFMNCorrections
453.300WQOB591RMCC7 TG* SL*SCI MAH OpsSCI Mahanoy OperationsDMRCorrections
453.675WQOB591RMCC7 TG* SL*SCI MAHSCI MahanoyDMRCorrections
453.8375WQOB591BCSQSCI MAH PerimeterSCI Mahanoy Perimeter AlarmFMNCorrections
453.325WNNM806RMSCI FRASCI FrackvilleFMNCorrections
453.825WNNM806RM203.5 PLSCI FRA OpsSCI Frackville OpsFMNCorrections
465.1125WNNM806BCSQSCI FRA PerimeterSCI Frackville Perimeter AlarmFMNCorrections
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Capacity Plus will emit a data burst every few seconds on the active "rest channel" & the audio emission will sound like this, though the bursts are often spaced further apart. Additionally if you have a Uniden Scanner with the DMR paid upgrade installed you'll see CAP or CAP+ (depending on model) flash up on the screen
tvengr
Well Known Member
Baltimore County, MD
SCI Camp Hill (Cumberland Co)​
FrequencyLicenseTypeToneAlpha TagDescriptionModeTag
453.325WQDW272RMCC 3
TG *
SL *
SCI CH OpsSCI Camp Hill OperationsDMRCorrections
453.450WQDW272RMSCI Camp HilSCI Camp HillFMNCorrections
453.875WQDW272RMCC 5
TG *
SL 1
SCI CH Maint 3SCI Camp Hill Maintenance 3DMRCorrections
TG *
SL 2
SCI CH Maint 4SCI Camp Hill Maintenance 4DMRCorrections
460.4875WQDW272BCSQSCI Camp HilSCI Camp Hill - Perimeter AlarmFMNCorrections
