Game Commission NC region is partially operating on the P25 system. Also, you can hear PEMA activity in the Harrisburg area.
I can confirm hearing 11443, 11444 and 11447 from Franklin County on CUMB04 and FRAN02, 11514 from Lebanon County on DAUP01, 11402 and 11405 on CUMB04 in Adams County, 11464, 11169 and 11171 from Dauphin County, 11163, 11164 and 11165 from Cumberland County on CUMB04. I have heard "Line Painting" on 11194 from both Lancaster and Dauphin Counties (wonder if it is a D8 wide TG ?). Hope this helps some. I am in Manchester, MD with an amplified discone and several 8 El. Yagis.
; DOT 8-4 York Line Painting 11169
P25, BEE00.942, 11169, 1781808, 50, Normal, 0, 0000/00/00 0:00, "DOT York 11169/11765"
P25, BEE00.942, 11169, 1781919, 50, Normal, 0, 0000/00/00 0:00, "DOT York 11169"
P25, BEE00.942, 11169, 1781925, 50, Normal, 2, 2019/09/25 13:11, "DOT York 11169"
P25, BEE00.942, 11169, 1781932, 50, Normal, 0, 0000/00/00 0:00, "DOT York 11169"
P25, BEE00.942, 11169, 1783055, 50, Normal, 1, 2019/11/01 6:19, "DOT York 11169"
; DOT 8-7 Lancaster Line Painting 11194
P25, BEE00.942, 11194, 1781876, 50, Normal, 251, 2019/11/15 14:57, "DOT Lanc830 Cindy 11194"
P25, BEE00.942, 11194, 1781877, 50, Normal, 277, 2019/11/15 13:20, "DOT Lanc Mike 11194"
P25, BEE00.942, 11194, 1781878, 50, Normal, 163, 2019/11/15 13:19, "DOT Lanc 11194"
I use both.
DSD+ does EVERYTHING a scanner does. Not sure why you'd think less of it as a tool (as far as figuring out who's talking to whom about what and where..) Blah, blah, blah You can record each call with TG & RIDS (with alias' if known) Just saying.. Look forward to hearing about what you find in Dauphin and the surrounds
They must have done the same thing on US-22 leaving WV toward the Moon/Robinson area. I always joked going past there that it was the PA Welcome Center!I know for sure that they stop at the Berks Co line and turn around They always mention a Porta Pot there and if anyone needs to stop
Someone needs to wrap some detcord around those 152.180 transmitters and blow them to kingdom come. Absolutely awful, they s%#t up the entire lower VHF band when they kick on.My dongles just have a really hard time with intermod/desense from Schuylkill Mobile Fone. In Luzerne county, I completely lost a Wayne Co CC while the pager system was TXing. Not nearly the issues here in Dauphin on 158.76 since it's quite a bit further from 152.180.
11514 talked about stockpile 5 today on the Ellendle VHF site. Not sure which district they are though.
TG 1 lit up today with Wayne talking about seeing helicopters coming down but his compadre saying there are no helicopters coming down on his end. I assumed they were radio techs until I heard them using unit numbers (22 and 790A or 798).
I heard some also from Truce on 11514
Likely the first TG to be confirmed for Lebanon
District 8-8 Lebanon County
Stockpile 5 Quentin
RID's
1782242
1782244 "hey I've been checking it"
1782247 "don't break the spinner in that truck"
1782266 "go ahead and load whenever your ready Barry I can't get anybody live"
1782272
11512 Is likely one as well...
Also heard what is likely to be North Central PGC Avis Dispatch 1233006 C6 doing radio tests on 12024
