PA Turnpike simplex 159.000
scanner92us
Somerset PA
Here in Somerset at exit 110 a pl of 136.5 is now being used on this frequency. Is anyone else noticing this anywhere along the turnpike? I'm curious to see if this is statewide.
ECHO3
Pennsylvania
Districts 1, 4, 5 use a repeater input of 179.9 and an output PL of 136.5
Districts 2 & 3 use a repeater input of 179.9 and an output of 94.8
scanner92us
Somerset PA
I'm aware of the repeater tones and I have them in my scanners, but I'm talking about the simplex car to car frequency of 159.000. Until recently there was no pl on this channel. Over the past week I have confirmed that 136.5 is being used on 159.000 in the Somerset area. Anyone else noticing a pl on this frequency out there? If this is statewide then all turpike channels would now have a pl.
gccflscan
Banned
PL or DPL
Are you sure its a PL of 13.65 and possibly not a DPL which can cause falsing on 136.5?
If the 136.5 shows up at the start and end of TX then its probably a falsing on DPL, try to see if it has a DPL code.
scanner92us
Somerset PA
Yes I tried that. I'm sure it's a pl, nothing showed up on dpl. I'm using a Pro-92. I've entered the pl and closed the bank and hear the traffic.
HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
The 136.5 PL has been active on PTC channel 6, 159.000, for a few months now here in District 4.
scanner92us
Somerset PA
It's looking like an update to the PTC database may be in order. I'm glad they're using a pl now. My base scanner, a RS pro-2036 gets alot of images and intermod on this frequency. Not one ofthe better radios in this dept. CTCSS is pretty much a must on this unit.
csvff78
Pittsburgh
Last trip I had on the Turnpike I did not hear any traffic on 159.000 so I can't help with that. But, I did notice that the Turnpike has changed the PL's to the inputs.
MM 000 - 100 (Ohio Line - Donegal) 156.195 PL 136.5 input, 159.045 PL 135.5 Output
MM 100 - 200 (Somerset - Everett) 156.225 PL 94.8 Input, 159.075 PL 94.8 Output.
Frank K3FSS
http://www.geocities.com/csvff78/pghradio.html
n3obl
Ø
PA
Looks like the input pl matches the new output PL's
will check and see if i hear D1 car to car on PL.
Frank
captclint
Mountaintop, PA
Dual Repeater Freq Use
All 5 Rptr. sites now use use both sets of TX/RX freqs for voice traffic, where as before they only had 1....
This dual Freq capabitliy (159.0450/159.0750)was reported as part of the new PL assignments. Any evidence of this? If so, I would assume both would use same PL assigned to district.
svw
palmerton pa
district 5 is using 136.5, the ambulance service i work for covers the t-pike, i will find the actually paper from the t-pike and post the freqs and pl i have
scott
