Pager Channel for Motorola HT1250
Mark181
Ocean County, NJ
Hi, does anyone know how to make a pager channel for a Motorola HT1250, s then the channel will only be open if it receives an alert or tone?
wcoriston
Buff.
Ulster County, New York
In the CPS go to the signaling tab, then quick call ii, set your tone type, go to ID tones and set actual tone frequencies. Under the channel you want to be the "pager" in conventional personality select the signalling tab and choose quick call under the RX system.
Ant9270
The Green Weenie
Everything WCoriston said above is correct. However, if multiple departments are being toned on the paging frequency and you only want to hear dispatches that are specific to you, set the mute type to “and”
Mark181
Ocean County, NJ
In the CPS go to the signaling tab, then quick call ii, set your tone type, go to ID tones, and set actual tone frequencies. Under the channel, you want to be the "pager" in conventional personality select the signaling tab and choose a quick call under the RX system.
Thanks! Where exactly do I put in the tone ID, and what do I do if I don't have the exact tone id?
And is it possible to set this up when the dispatcher just alerts and does not do a tone?
K2NEC
Signaling>Quik-Call II System>System 1>Individual ID Tones
Doesn't help you if you don't know the tones. There is an app out there for your phone that can decode them but IDK how accurate it actually is with the tones.
Not sure what you mean by just alerts and doesn't do a tone.
Mark181
Ocean County, NJ
Thanks! Well there is 2 alerting systems, MDC CALL and Quik-Call II, is there a way to set up a pageing channel that will detect the MDC CALL and open the channel? Also what is the name that app
n3obl
Ø
PA
No you have to select on the channel one rx system so either QC or MDC
