Paging on LTR
INDY72
Indianapolis, IN
Does a paging format exist for LTR systems of any format?
LTR
Ohio
You can use DTMF, or if you are using Kenwood radios they have their own signalling protocol called "FleetSync" that can be used to page, or use as a private call.
INDY72
Indianapolis, IN
Thanks.. I had heard some interesting tone sounds on an LTR I was working on figuring out, so was wondering about that.
(Finally getting around to the business LTR's in my area.. I spend so much time figuring out the PS stuff,.. sometimes I forget all about the business stuff.)
LTR
Ohio
The Kenwood FleetSync format sounds similar to Motorola MDC1200, if you have heard that before.
FleetSync can have unit ID either before or after the transmission, and send alpha numeric messages to the radios that scroll across the display screen, or a Kenwood MDT terminal. FleetSync can be used in either conventional or LTR trunked, (I also believe that Kenwood is working on it for PassPort too).
This may be what you are hearing.
INDY72
Indianapolis, IN
Might be as I know one of the companies that is on this LTR uses Kenwood MDS's, and Kenwood Mobiles. They used to run Nextel's but found it cheaper to join on the local LTR SMR.... More later...
LTR
Ohio
If they have the Kenwood MDT's in their vehicles, then I would say that definately you are hearing the FleetSync signalling.
