Brian, what do you think the reasoning is behind all of the TG changes occuring and in the near future??It's DPS Troop 4, the "replacement" for talkgroup 30224. We'll see many talkgroups change over the next several months. Most of the known SCHP talkgroup changes are listed in the DB and the wiki.
I confirmed this talkgroup through data gleaned from Trunk88, a trunked control control channel decoding package. 45808 and 30224 have been patched together from time to time over the last several months.
That's a good question that I don't have a good answer to. I suspect that the radio managers are using the opportunity of reprogramming subscriber radios for rebanding to make other changes in advance of the migration to full P25. That may or may not be true, and if it is true, I don't have a technical explanation of what those changes for P25 are.Brian, what do you think the reasoning is behind all of the TG changes occuring and in the near future??
Looks like I need to do some database updating.Anyone have any idea what the following TGs may be? Hearing them in Spartanburg Co.:
17360 (hearing plates run on it)
17328
45808
48912
Unfortunately, I do not. Perhaps someone will speak up.Brian ...
Do you know of anybody in Beaufort County who would be able to help programming my Scanner?
Well, you're not going to get a whole lot of use out of a PRO-95 in Beaufort County, at least for listening to local public safety agencies. Beaufort County fire, ems, police, and other agencies operate on the Palmetto P25 system, which uses digital modulation. The PRO-95 won't decode those digital signals. You could use it to monitor amateur radio, commercial and military aircraft, and maybe some neighboring counties' public safety agencies and some state agencies. That's about it.Somebody gave me a Radio Shack pro-95.
I thought Beaufort County simulcasted fire dispatch on the VHF frequenies?Well, you're not going to get a whole lot of use out of a PRO-95 in Beaufort County, at least for listening to local public safety agencies. Beaufort County fire, ems, police, and other agencies operate on the Palmetto P25 system, which uses digital modulation. The PRO-95 won't decode those digital signals. You could use it to monitor amateur radio, commercial and military aircraft, and maybe some neighboring counties' public safety agencies and some state agencies. That's about it.
Sorry for the bad news.
