palm 800 question
gaunter033
I would like to know if this is possible with the pro 95 using win95 and if so will it work like I am thinking it will.........which is, as I drive thru the cell areas, I will pick up the local talk groups I put in?
I want to put certain control frequencies only for certain cell cites that I want to travel thru in south carolina in bank 9. OK, now once I install all of the ID codes for those areas that I will travel thru and I am sure that everything is in motorola type 2 mode and I close the bank do I need to change anything in the upper right hand corner box where it says "Motorola UHF-lo settings" or no? Sorry if this is a dumb question but I want to be sure I get it right the first time.
Its a motorola type 2 smartnet analog system on the palmetto 800
