transitman
The RR database currently lists the Palm Beach County System as a Motorola Type II Smartzone. While recently attempting to monitor this system using a RS Pro-96 and the frequencies shown in the database, no transmissions were heard nor was a control channel evident when the frequencies were set to Motorola mode (all frequencies were entered). After boarding a Palm Tran bus, I discovered the radios used were EFJohnson model 5300 which I believe are not compatiable with Motorola systems. Fortunately a call came through over the bus radio and I was able to monitor the conversation using FM mode. The conversation lasted long enough to scroll through the various mode options. No group display appeared when set to LTR, however when set to Motorola, a group number appeared which corresponded to the RR database. So, is this system a Motorola Type II or LTR Multinet? Your thoughts and comments are requested!
