panel lighting suggestions
kc7vtr
I have Yaesu FT-8800R dual band transceiver with the head remote mounted on the dash. One major complaint is that the buttons and knobs aren't illuminated which, along with their small size, makes night time operation a bit dicey. I'd like to mount some sort of small light(s) above and facing the panel. It doesn't have to be very bright, just enough to show the white markings.
One thought is a couple of LEDs pointed toward the front panel (either red to sort of match the orange display or green to sort of match the dash lighting). Any other suggestions?
radio10-8
West Coast
call a local musicians store and ask if they sell audio mixing boards. If they do they might carry these lights that attach to the board so teh tech can see the knobs and buttons during a dark concert. Some attanch via BNC connector and I have seen some that are USB so if you have a computer nearby you can do teh USE light. Ihave a USB light made by Kensington and I love it.
N4JNW
Irvine, KY
Go to Advance Auto Parts and check out one of the big tall "racks" that are usually up next to the registers, where all the "import tuner" accessories are.
There are usually some sort of "mood" lights there, I once picked up a pack of 3 small "can light" type LED lights that had a 12V ciggy lighter plug, and the bases were sticky. Peel off the tape, stick them where best, and wire up.
kjfswkr
Title: Littlite® Gooseneck Lamps
Features
Flexible, durable gooseneck.
High quality construction.
Sleek, low profile design.
Sharp, bright white light.
Rheostat dimmer control or on/off switch.
Available in 6", 12", and 18" lengths.
Littlite gooseneck lamps provide excellent illumination where space is at a premium. Using halogen technology, the high intensity lamp emits crisp, bright light in a tightly controlled pattern. A red filter is included for nighttime use.
Littlite Model LF6ESB is a 6" lamp with on/off switch, neck extends from end of chassis.
Littlite Model LF6TSB is a 6" lamp with on/off switch, neck extends from top of chassis.
Littlite Model LF12ES is a 12" lamp with on/off switch, neck extends from end of chassis.
Littlite Model LF12TS is a 12" lamp with on/off switch, neck extends from top of chassis.
Littlite Model LF18ES is a 18" lamp with on/off switch, neck extends from end of chassis.
Littlite Model LF18TS is a 18" lamp with on/off switch, neck extends from top of chassis.
Download More Info
Click here to download our Littlite® Gooseneck Lamps PDF file. It contains more product information, diagrams, ordering instructions, and spec-able information. To view and print this file, you will need the Adobe Acrobat Reader software.
This application can be downloaded for free by clicking on the icon below.
check these out. Federal Signal has them
Kevin
OpSec
KEK'ing my TEK
Monitoring the database
+1
I like these lights for a lot of applications, both fixed and mobile. In this particular case, a 6" light affixed to the side of the control head would work out great.
