I want to get a good match for 15m on my 40m dipole. I have seen several sources that recommend using capacitance "hats" at ~11 ft from the feed point e.g.:
https://www.na6o.com/amateur_radio/ewExternalFiles/40_and_15m_dipole_NA6O.pdf
I have also seen one recommendation to add parallel 15m wires:
The 40 and 15 Meter Dipole - a Myth Exposed
But, other sources say this should not be done because the input impedance will become too low; the argument is that since the 40m wires are close to resonant on 15, if you add 15m wires, you will have two ~50Ω antennas in parallel and the transmitter would see 25Ω.
However, when I analyzed my 40m dipole, resonant at 7.058 MHz, with a RigExpert I find that |Z| at the resonant freq. is 59Ω, while |Z| at 14.058 is 29Ω. Yet nobody would object to adding 20m wires in parallel to a 40m dipole!
Obviously I am missing something... am I misreading the RigExpert? Do we need to consider the complex impedance and not just the absolute value of Z? Can someone explain how impedance really works in dipoles fed from the same coax? And if adding 15m wires is a reasonable option or not?
Thanks!
(PS. I am not asking for antenna recommendations, or suggestions to use a tuner. I am asking for help understanding how the parallel dipole configuration works vis-a-vis impedance... THX)
Thanks!
