Parking on a control channel
04Z1V6
Castle Rock, Co.
I have forgotten how to park and move through control channels on a BCD396XT. I am using pro96com on a P25 system and I use my pro-106, but, I am trying to compare a few things with the two. How do I "park" on a control channel with the BCD396XT?
KE4ZNR
Radio Geek
Just make sure the active CC is programmed into a system then hit "hold" while on the CC.
Also make sure your CC Output is setup to "On" under Settings->"Set C-Ch Output".
Marshall KE4ZNR
04Z1V6
Castle Rock, Co.
Thanks. This jogged my brain. I was missing how I could page through the cc and not the tg's. In case someone needs to do this, this is how. After you have parked on hold then press the function button and then page through the CC's by twisting the select or volume button. Thanks again to KE4ZNR and 73's to you sir.
