parma pd scanner
stiltipn44s
Parma, OH
im looking to buy a scanner to listen to the parma pd but not sure which one to buy or where to buy it at. if anyone could help it would be appriciated. i know nothing about scanners and im not sure which one would work because of parma switching to p25. i dont want to but the top of the line equitment either because i will only be using it on a limited basis.thank you in advance.
ron
PFalconflyer
Cleveland, Ohio
Parma PD is currently utilizing an edacs trunked 800mhz analog system, but they presumably will be switching to all digital P-25 in the near future (The P-25 system is up and was already used for a week or so, before Parma PD switched back to edacs.
With this in mind, you definitely want to look at digital scanners. You didn't mention whether you are looking for a handheld scanner or mobile/desktop scanner. I am most familiar with the handhelds, as that is all I have ever owned. The most common digital handhelds available today are:
Radio Shack Pro-96 : Discontinued, but you might be able to find a used one for ~ $200
Uniden BC396
GRE PSR-500
Radio Shack Pro-106
Other than the Pro-96, which is getting a bit "dated", the other three are pretty much state-of-the-art scanners that will likely cost you between $400 and $500. The PSR-500 and Pro-106 are functionally equivalent, and are both manufactured by GRE. You would have to compare features between the Uniden and the other two to decide which is more to your liking. I have a Pro-106 and love it!
If you are looking to buy locally, you can obviously find the Pro-106 in Radio Shack stores (if/when they are in stock). Locally, you can buy the GRE PSR-500 and BC396 at Amateur Electronic Supply (AES) on Euclid Ave in Cleveland. Alternatively, they can be purchased online from various vendors.
Let me know if you have more specific questions.
-Pat
Nasby
Ohio
Also consider joing a Yahoo group called: NEOhioScanner. They have had very lenghty discussions about Parma's radio system as well as other Cleveland area scanner issues.
stiltipn44s
Parma, OH
wow thank you guys both. i didnt expect so much info. i will probably look into the pro 96 i think it was you said because i dont need state of the art equitment, but when they switch back to p-25 i still want to hear it. i appriciate the help and will look into it tomorrow. thanks again
ron
