ETMegabyte
Currently I am broadcasting to RR LIve audio using ScannerCast. I am also using Windows Media Encoder to stream to a webpage. Can I do both with SC or do I still need to run both? I also have a Droid and would like to receive my streams without having to go through RR (no offense to RR).
I don't send to RR Live, but my usage of the program leads me to believe that you can at least do the RR Live and the Droid both from SC. ScannerCast's configuration allows for direct port connections, with an option to send stream to icecast. It's the icecast setup that connects it to RadioReference, so my understanding is that they are mutually exclusive... The only thing you may need Windows Media Encoder is to embed it in a webpage, as I don't know what's involved in doing that...
If you set up the "Server Port" in the "Config" tab to 2080, for instance, and also configured RR Live, then RR Live would get the feed, and you would be able to connect to it directly through port 2080, which you can set up your droid to do. Port forward 2080 to your scannercast machine, and set up your droid to connect to port 2080 on your internet ip.
And, a final feature request. I could have sworn I had already suggested it, but I can't find that suggestion, so here it is... I'd like to have username/password authentication on my direct feed. For some reason, even using an alternate out-in-the-middle-of-nowhere port, I keep getting connections from "rate-limited-proxy-##-##-##-##.google.com", which I'm led to believe is a google feedburner bot. They must have port scanned me and found an http response so now they parse it. I have no way to tell them to stop connecting to me, so I'd like to be able to put in my phone "http://user : pass @ ipaddress : port / stream.mp3"... Then bots wouldn't be able to connect, and if they do, then I can just change the username and password...
