Anyone else ever run across one of these which lacks sensitivity even after the BPF adjustment routines are performed via software?
As an example, a 1mV amplitude signal at 149.9700 MHz gives a sample S-level value of 128 when applied to the unit's Antenna connector; this seen in the EX2099 program's dashboard. Knock the generator amplitude down to 0.1mV (not uV, mind you) and the received signal gets very noisy. With just about any other VHF FM receiver I own, even a 20uV signal applied to the Antenna connector results in full quieting and a noticeable S-meter reading/derived AGC voltage.
If I use the generator to apply a signal to "CP5" - just ahead of the 1st Mixer - a little increase (but not much) in signal level is noticed. This leads me to believe something's up with the BPF section of the RF Unit. The receiver appears deaf everywhere - not just on one band.
Suggestions and observations welcomed.
73 - Fred, N8YX
73 - Fred, N8YX
