Partitioning Software
crazyboy
NJ
Does anyone know of any good, preferably free, partitioning software? Thanks
NightFox
Lafayette, Indiana
If you have Windows XP then you have a partitioning tool already installed. I believe that it's in the system tools under the start menu but I could be wrong since I'm not on windows atm.
MacombMonitor
If he's partitioning a new drive, or free space on an existing drive, then yes. However, if he wants to change the size and number of partitions without loosing data, then he can not use the partitioning tool in Windows XP. As others have pointed out, he will need Partition Magic, or something equivalent.
If using Partition Magic, make sure your version is new enough to be fully compatible with Windows XP. Early versions are not, and will corrupt your drive. It is probably the best tool for the job.
cschmit
Wauwatosa, WI
If you are partitioning a drive with data on it make sure it is BACKED UP!!! I have seen several unsucessful partitions with Partition Magic so make sure all your important stuff is backed up.
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
there are some free Linux apps but I don't use Linux enough to suggest anything. I used to like Partition Magic but now it's not as good as it used to be. I like Acronis Disk Director 10. and yes BACK UP YOUR STUFF!!!! and do it to a media like DVD or CD or another hard drive that you will physically remove from the PC prior to doing anything.
http://www.acronis.com/homecomputing/products/diskdirector/
crazyboy
NJ
For backing up I used Windows backup wizard and am going to put it on another computer on my network to another computer. Looks like i'm going to use Partition Magic. Thanks
bwhite
Balto/Carroll, MD
I'd go with Partition Magic unless you don't value your data.
If it is a pc you don't care much about or don't have data on you can be a bit more caviler about it since your risk is reduced.
mike_s104
that's a version of Linux, correct? it probably comes with a free partition software like LILO or Grub. I would BACK UP EVERYTHING and try the install CD. if you just want to play with it, try VMWare and run it under Windows XP.
if you just want to play with Linux, there are a ton of other versions. all are a little different. there are live distros on CD. you could try these on your PC booting from the CD and it will leave your WinXP install untouched unless you do something to the drive from within Linux. you can find other Linux distros here:
http://distrowatch.com/
crazyboy
NJ
Yes, it is a version of Linux. This one can run right off the cd but I would like to install it. It has partition software in it named Parted.
