Here is a list with the price, and will tell you if it is in stock or not.
RSU # Description Sug. Retail Availability Additional Description
11318532 DIODE 1N4002 RECT 600V.1A SI $.29 In Stock
10539476 ANTENNA,RUBBER 15.8CM $10.99 In Stock
12357570 CRYSTAL 20.945MHZ $8.13 In Stock
12357687 CRYSTAL 12.288MHZ $11.11 In Stock
12410833 COVER ASSY BATTERY $3.69 In Stock
12228805 HOLDER ASSY FOR RECHG. BTRY'S $5.99 Not In Stock
12228813 HOLDER ASSY BATTERY $5.99 Not In Stock
12410841 KEYTOP $13.89 In Stock
11274966 CLIP,BELT (FOR SCREWS 11717493 $2.79 In Stock
10720209 JACK,ANTENNA $8.29 In Stock
11840063 JACK,EARPHONE $2.87 In Stock
12228714 JACK POWER $2.49 In Stock
12193892 KNOB VOLUME/SQUELCH $2.49 In Stock
12357752 LCD $36.79 Not In Stock
12410783 LED FY1112H-1-TR $3.89 In Stock
12410858 MANUAL USERS 20-526 $4.99 In Stock
12411146 PRE LOADED PROGRAM GUIDE $2.49 In Stock
12357695 IC EEPROM HN58X24256FPI $17.99 In Stock
12410775 IC SMT TMP93PS44F $54.99 In Stock CPU 16-BIT MOS
12417416 SQUELCH ASSY $5.29 In Stock
10983344 POT ASSY,W/SWITCH VOLUME $8.75 In Stock
11717485 SPEAKER 8-OHM 500MW $11.89 In Stock
12410759 PCB ASSY LINEAR $139.99 In Stock
12410767 PCB ASSY LOGIC $249.99 In Stock
12410791 CASE ASSY FRONT $28.49 In Stock NON REPAIRABLE CONSISTS OF: CASE FRONT WINDOW LCD TAPE ADHESIVE HIMELON SPEAKER
12410809 CASE ASSY REAR $17.69 In Stock NON REPAIRABLE CONSISTS OF: CASE REAR GRIP (L)/(M)/(S) LABEL MODEL TAPE ADHESIVE FOR GRIP(L) TAPE ADHESIVE FOR GRIP(M) TAPE ADHESIVE FOR GRIP(S)
