Pasco county fl. Help
EDOG25
can someone please tell me what the pasco county signals are. I got the the 10-4 list but no signal list. Also any info you may have about pasco conty scanner info would be great I just moved here. Thanks alot.
EDOG25
That was not it
This is where I got the 10-4 list but this does list the signal list.
ctrabs74
California, PA
edweirdFL said:
If you go to the page for the county here
http://www.radioreference.com/modules.php?name=RR&ctid=366
you can click on the FCC licenses tab to get a report for the county, and then try and see if there are any on the report that are not listed on the page.
I think he meant radio codes such as "Signal 1", "Signal 2" etc. IIRC, don't most of the counties in Florida use the same radio "Signal xx" codes state-wide (ie. "Signal 7" = DOA)?
