ticoman71
Anyone monitoring the Paulding County DMR system? I have an Uniden BCD436HP with the Motorola Turbo license key... All I hear is PCSO dispatch on talkgroup 100 but really nothing else! No Fire or anything else... Any ideas? Thanks
Did you ever get it to work? Let us know.Anyone monitoring the Paulding County DMR system? I have an Uniden BCD436HP with the Motorola Turbo license key... All I hear is PCSO dispatch on talkgroup 100 but really nothing else! No Fire or anything else... Any ideas? Thanks
The early versions of the BCD436HP have an issue with poor reception in the 400 Mhz range. Here's something simple you can try to see if it improves your reception.Still trying to figure out what the deal is here... Found that if you hold the fire channel (and other channels), it will receive traffic just fine all day long, but never when in scan mode. I am lost as to WTH is going on here. Bad database info? Defective scanner?
I listened to Paulding this morning and it stopped on the Fire channel as it normally would. I am afraid the problem is with your scanner. Look to make sure you don't have the fire channel locked out. You will see L/O on your screen if that's the case. On my Uniden 325P2 if you hit L/O once it temporarily locks it out, if you hit it twice it permanently locks it out. To unlock it, just push the L/O button.Still trying to figure out what the deal is here... Found that if you hold the fire channel (and other channels), it will receive traffic just fine all day long, but never when in scan mode. I am lost as to WTH is going on here. Bad database info? Defective scanner?
