On the Plano, Allen, Wylie, Murphy (PAWM) P25 database page, it states that some talkgroups in the system use the Motorola X2 TDMA. Is there any knowledge of what talkgroups use this?
That answers that, is there any X2 on McKinney as shown in the DB?
Although the PAWM system is capable of using Phase II, at current there are no identified talkgroups using that mode. Those would be identified in the Mode column of the database page with a T, for TDMA capable. At present, everything listed is flagged as D, for a digital talkgroup.I'm a 250D owner that got away from scanning when rebanding occured (also no P25 card). This year Santa fixed me up with a new 396XT, so I'm in the process of learning about DMA along with new systems in use in my area. Also a first time FreeSCAN user.
As a trial run, I programmed Wylie PD under P25 Std system using FreeSCAN and typing the freqs / TGs. I'm getting traffic, but it seems a little limited compared to what I remember. Can a 396XT still fully track the Plano Allen Wylie system, or is X2 TDMA (Phase 2?) playing a larger role on this system. FYI - Squelch is set to "2" if that matters. Also its raining here at the moment if that tends to cut down on the traffic stops.
Also, when I tried to import the rest of the system from RR using FreeSCAN, its brings the system type in as P25 Phase 2 (Untrackable). Can I just change the system type to P25 Std (what the 396XT supports) before uploading to the scanner? Will I lose the correct data?
Apologies if I'm not grasping the full P25 concept and how all of terms relate to each other. Any insight would be appreciated.
Just a thought here-I'm noticing the same thing. I was holding on Wylie PD Dispatch and on two separate instances I heard the dispatcher confirm transmissions from officers that I never heard. Am I experiencing this overload? I guess I'll break out the race track stubby and try that.
It reports as an X2 system. While there are no X2 talkgroups the system type as X2 is accurate. The message, however, is misleading; perhaps the message should read that the system is capable of using X2 talkgroups. The band plan also shows two slot table entries; a further indicator of X2/P2 capability..
Thanks,
Russell
